SQL error
- Roger Ramjet
SQL error
When trying to send a private e mail all you receive is an SQL error message.
Re: SQL error
I am getting it intermittently whenever I try and access a new page from the main index
Re: SQL error
Are you still seeing the problem? Everything now seems to be OK as far as I can tell.
Re: SQL error
Stopped for me, no more error messages or attempted re-directs
- Sometimewoodworker
Re: SQL error
The error is back when trying to send a PMdozer wrote:Are you still seeing the problem? Everything now seems to be OK as far as I can tell.
General Error
SQL ERROR [ mysqli ]
Incorrect string value: '\xF0\x9F\x99\x8F\xF0\x9F...' for column 'message_text' at row 1 [1366]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
Please notify the board administrator or webmaster: dozer@coolthaihouse.com
Jerome
http://bit.ly/Building-and-land-thailand all pictures, current build
http://bit.ly/GMnewHouse Grand Mums New house : http://bit.ly/WaterhouseTimeLine
http://bit.ly/JeromeOtherPics general stuff : http://www.flickr.com/photos/nui-jerome/
Re: SQL error
I have now isolated the problem. There is a new emoji "wai" symbol and I was forwarding it in my message.Sometimewoodworker wrote:The error is back when trying to send a PMdozer wrote:Are you still seeing the problem? Everything now seems to be OK as far as I can tell.
General Error
That was causing the SQL error So maybe I can only use approved smiles
Jerome
Re: SQL error
Should be back up again now.
