This should be fixed now, can you check it? I had implemented a feature to allow selective albums to be viewed by groups which should not have affected any current albums but your album for some reason had limited visibility setting which has now been corrected.
Sorry about this. I know it would be somewhat frustrating. I believe I have fixed it now, it was due to a necessary 'hack' to the photo album software that I made. This caused one of the data fields regarding album visibility to be set to the wrong value. The prior time I looked at this I had noticed and fixed the 'incorrect value' without correcting the original hack. (So a further update to the album would cause the incorrect and wrong setting again.) Now I have corrected the bad value along with the hack. Can you try it again and let me know? (also some other users were impacted and have also been fixed)
