Postby Sometimewoodworker » Sat Jan 31, 2015 2:08 pm
The start of the slow build of Baan P'Nui and Jerome.
Stage 1 provisional plans, to be revised, Front
The 2 part roof at the front is going to become 1.
The upper windows will reduce in hight by 50 cm (currently 1 metre) & so upper roof will be lowered
Roof overhang will increase from 1.5 to 2.5 meters
Stage 1 provisional plans, to be revised, floor plan.
My concept sketchup model
Postby fredlk » Sat Jan 31, 2015 2:43 pm
I'm missing the 2nd floor .....
I'm sure I saw it in your iPad or is my Oldtimer's really kicking in?
Postby Sometimewoodworker » Sat Jan 31, 2015 3:16 pm
fredlk wrote:I'm missing the 2nd floor .....
No you Oldtimer's still not here yet.
SWMBO decreed that she doesn't want to clean the second floor so it's gone and the ground floor grew a bit.
Postby pipoz » Sat Feb 28, 2015 10:54 am
Thanks fixed up the Fan drop pole mounted issue, with them.
Spoke with him yesterday and got confirmation it was a DR Model (the drop pole mounted) and not a HR Model (ceiling mounted)
Postby Sometimewoodworker » Sat Aug 08, 2015 10:11 pm
Moving along slowly but moving.
We have just had a visit by our architect and a professor who has a sideline business testing the load bearing qualities of soil for building locations.
Soil strength testing
Core sample
After getting the results from the testing our foundations may be able to be reduced in size.
Postby pipoz » Tue Aug 11, 2015 12:23 pm
Interesting, I would have dug a hole 1.5 m deep and done on a CBR or Plate Bearing Test, unless of course you suspect a problem with the soil strata beneath that. Suppose it depends on whether you are also in a flood prone area
Are you planning on Piles or Pad Footings for your foundation
Plate Bearing Test - 1
Postby Sometimewoodworker » Tue Aug 11, 2015 2:20 pm
pipoz wrote:Interesting, I would have dug a hole 1.5 m deep and done on a CBR or Plate Bearing Test, unless of course you suspect a problem with the soil strata beneath that. Suppose it depends on whether you are also in a flood prone area
We just went with the recommendation of our architect. I suspect that a CBR would have taken very much longer than the 4 or so hours, and I'm not sure if it's available. That's why we used an STP (STANDARD PENETRATION TEST)
As to flooding, no risk. As to foundations they will be pad as probably piles, unless drilled, would be impossible. At the moment our foundations are based on an 8ton per sqm but it is much more likely that our soil is 30 tons or higher we are still waiting on the report.
Postby Sometimewoodworker » Sun Nov 01, 2015 4:30 pm
Things are moving along.
The foundations will now be 1 meter deep. This is well within the fill we added, as it has compacted nicely
STP results
There has also been a first ceremony asking the Buddha for good luck, I've just heard that the lottery number today is 11 and that's the scheduled official start day, so maybe it worked :?
The local Buddha
There was an offering of a pigs head.
pigs head Offering
That in true frugal Thai style was then eaten by SWMBO and friends.
Postby Sometimewoodworker » Sun Nov 01, 2015 4:42 pm
We also located the kind of floor drain I've been looking for in Bangkok.
Linear drain 1
Linear drain 2
Floor fitting
Postby Sometimewoodworker » Mon Nov 02, 2015 4:52 pm
I forgot to post the revised plans
Front of the house
Floor plan, almost final
There will be a slight change the ramp will be narrowed to allow for 2 vehicles parked in front of the loading bay door
Postby Sometimewoodworker » Tue Nov 10, 2015 1:52 pm
I also have a first approximation Sketchup model that has been revised and a final version CAD file
Sketchup front view
Sketchup side view
CAD side view final
Postby Sometimewoodworker » Tue Nov 10, 2015 1:57 pm
We have had the land God ceremony, a small short affair that has to take place before breaking ground
Postby Sometimewoodworker » Tue Nov 10, 2015 2:18 pm
As I mentioned before The official start of building, the Sao Ek- Sao Toe first post ceremony is tomorrow 11/11
Architect marking out foundation
In preparation for that we have a lot of holes. And as wh have about 30 of various sizes we got a baby maco
Baby Maco
Baby Maco And SWMBO
Double foundation hole
Postby Sometimewoodworker » Thu Nov 12, 2015 10:03 am
Yesterday was the official start of building, the Sao Ek- Sao Toe first post ceremony
SWMBO was very happy with how it went and has gained a lot of "face" because of the guests who came including the OrBoTor, teachers, village heads and others
Footing rebar 150 mm off the base, as specified by our architect.
Everyone helping for luck
Guests adding money to the fish trap for luck
Nui putting in our good luck money under every post 9฿ For every one
A cousin also adding good luck money
Postby Sometimewoodworker » Thu Nov 12, 2015 10:46 am
More 11-11 pics
SWMBO dressed up for the ceremony
Thai and food
Eating
Very proud Grand mum because everyone is paying respect to her
