Udon Thani Happy House
Postby pipoz » Sat May 17, 2014 1:14 pm
Finally decided to start the process of a more permanent house.
Having started with a simply Bamboo House, whilst trying to buy the neighbours land, I gave up waiting for him to sell and decided to build in several stages, starting with a Studio-Guesthouse. I will just have to starve him out, over the next six months.
Pictures of my Bamboo house, which will serve as a shelter for the workers an eventually be demolished in 3 - 4 months’ time.
Attached is the "Happy House Concept", with a Studio Guesthouse at the Rear (sits just in from of the Bamboo house) and then the Main House in Front.
Bamboo House
Bamboo House
Happy House 001.pdf
HH Concept 001
(181.78 KiB) Downloaded 116 times
Re: Udon Thani Happy House
Postby pipoz » Sat May 17, 2014 2:57 pm
Having decided to kick off with the Studio Guesthouse, next step was to choose a Façade concept and develop some drawings. Starting with the structure, I developed a set of structural drawings and added a few photos from CTH of what I wanted to achieve. (PS advanced thanks to other members for their kind photo donations)
Studio Guesthouse: Is 96 m2 Internal living area, with another 55 m2 for the Verandah are (External Paved area). Total Footprint is 151 m2 under Roof Line
Attached are some of the drawings for the set out-footings, foundation ground beams and slab, roof RC ring beam and external wall layout. If anyone is interested in them in AutoCAD or PAD I have them, but files are too large to upload on CTH.
Armed with some drawings of the Structure for the Studio-Guesthouse and a cost plan, I went to Udon Thani start of May and found a small builder through the local network. Sat with him end last week, agreed a price for the Structure only (as I am still developing the roof, façade and interior). Builder started on Saturday 10 May and said it would take him about 55 Days to complete the Structure/External walls. Fine with me.
Facade Concept for Studio Guesthouse
HH Facade Concept Part 1.pdf
Facade Concept
(102.13 KiB) Downloaded 269 times
HH Footing Layout Part 2.pdf
Set Out & Footings
(129.12 KiB) Downloaded 263 times
HH External Gound Beam B2 Part 3.pdf
External Pavement Ground Beam B2
(175.97 KiB) Downloaded 209 times
SHH Main House Ground Beam B1 Part 5.pdf
Main House Ground Beam B3
(137.12 KiB) Downloaded 199 times
HH Roof Beam B3 Part 6.pdf
Roof Ring Beam B3
(103.15 KiB) Downloaded 180 times
HH External Wall Block Work Layout Part 7.pdf
External Wall Layout
(136.48 KiB) Downloaded 200 times
Postby pipoz » Sat May 17, 2014 3:22 pm
Off and running Day 1 to Day 5, move some of my established trees, set-out, excavate, pay Buddha and pour some footings.
I managed to have time to check his set out and some footing excavations before I left, and all was OK. Now have to leave it in her hands and now have to rely on photos from a distance, whilst I go back to work.
The two basic rules I gave him, are that the Reinforcement has to be SD 40 or 50, (No less) and Concrete has to be from CPAC 280 Steng.
Day 1 Move some Trees- Plants
Day 2 Set Out and Excavate Footings
Day 3 Traditional Buddha Offer
Day 5 Pour Footings
Postby pipoz » Sat May 17, 2014 6:05 pm
Day 7 and back up to Ground Level.
Now have to do some work on the road and entrance (shift a electricity pole) for the bigger truck deliveries. Then Ground Beams should start mid this week.
Day 7 Footing Column Necks Poured
Postby Ians » Sun May 18, 2014 9:29 am
Good luck with your build, looking forward to seeing it develop.
Postby Makmak456 » Sun May 18, 2014 7:16 pm
Off to a good start....
Mark
Makmak456
Postby pipoz » Wed May 21, 2014 12:43 pm
Slow but steady progress. Expect to pour on Day 14
Day 10 Ground Beams
Postby pipoz » Fri May 23, 2014 1:02 pm
Day 12, pouring half the ground beams
Day 12 Half Ground Beams
Postby pipoz » Sat May 24, 2014 4:54 pm
Bought the largest one of these a few days back just to make, they (not her) use one, whilst I am not there.
Thaiwasatdu Conc Vibrator
Postby pipoz » Fri May 30, 2014 8:23 pm
Day 16 Ground Slab down.
Got a few quality problems, with the Thai's having done what they want and not what I want.
Can be fixed, but they do piss you off sometimes when they do their own thing
Day 16 Ground Slab Poured
Postby pipoz » Fri May 30, 2014 8:35 pm
Days 17 & 18
External Pavement Slab areas poured and Column Forms being erected
Should finish the structure (ring beam) in about 2 weeks
Day 17 External Pavement Slabs
Day 18 Column Forms
Postby Roger Ramjet » Fri May 30, 2014 9:46 pm
pipoz wrote:External Pavement Slab areas poured and Column Forms being erected
I like the size of the columns, but make sure they brace them after they use the level to make sure they are square.
Postby pipoz » Sat May 31, 2014 11:59 am
Hi Roger and thanks.
They are 250 x 250 mm with 8* x DB 16 bars. They should be 3 meter high to underside of the RC Ring Beam, if the guy reads my drawings.
Also under certain areas of the line of the ring beam for a meter either side of some columns there will be load bearing reinforced/concrete fill block walls. That's the intention
DRAWING-130.pdf
Roof Ring Beam Dwg 130
(249.96 KiB) Downloaded 159 times
Postby pipoz » Tue Jun 03, 2014 7:56 pm
Day 20 31 Saturday May 2014
Sorry about the photos, but have to rely on others to take pictures
FWK to Ring Beam Day 20
Postby pipoz » Sun Jun 08, 2014 9:26 pm
Day 24 view from the front
Like all things the Builder doesn't read the drawings, so I now have six extra columns at the front. The four in the center view, I will knock down.
Still better than leaving a column out.
Front View West
Front View Center
Front View East
