Building in Bang Khla
Re: Building in Bang Khla
Postby Alan » Sun Jun 25, 2017 1:44 am
Ready for a top coat of concrete.
Alan
Postby Roger Ramjet » Tue Jun 27, 2017 9:29 pm
Alan wrote:Ready for a top coat of concrete.
Not quite, as usual they have used the lazy method of "lifting" the trench mess and will tell you everything will be okay because they lift it after the pour. and then they'll walk on it again and it will not do the job it was designed for; keeping the trench mess in the center of the concrete about to be poured.
I used Lanko to bind the two different concretes together, otherwise you can have the bottom planks separating from the top concrete.
The trench mesh should be held together with 9mm rebar, straight or deformed it doesn't matter. When you pour the concrete you'll find that the trench mesh will shift if not welded to rebar, with proper chairs under it.
Postby Alan » Wed Jun 28, 2017 6:15 am
Hi Roger, the pictures I posted don't tell the whole story. I agree the process could have been better but let me tell you the rest of the story. After connecting all of the welded wire together my builder welded the wire to the rebar sticking out of the floor beams so it would not move (much). I'm not sure if you can see them but he made little concrete "chairs" throughout the floor. When pouring the cement he had to wheelbarrow most of it in place so he left the wire on the floor except for where he was pouring concrete. Where he was pouring he pulled the wire up on the chairs. The concrete was supposed to be 5cm thick but we changed it to ~9cm because he said it was too difficult to center the wire in such a small thickness. He also left sizable gaps between the ends of the planks and where the sides met any floor beams which required a little more cement but I think it adds a little more stability and support to each individual compartment (4mx4m area).
I think the final total of cement was 36m3. Will post some more pics soon.
Alan
Postby Alan » Sun Jul 09, 2017 12:36 am
Well the floor topping is done and their starting on the wall columns.
Wall Columns
Alan
Alan
Postby Alan » Sat Jul 15, 2017 9:00 am
More wall columns. Larger wall columns are required to support the composite beams that will be made to span the 8-meter spans in the living room, bedroom 1 and kitchen.
Alan
Alan
Postby Alan » Thu Jul 20, 2017 6:56 am
last of the wall columns
Alan
Postby pipoz » Thu Jul 20, 2017 3:05 pm
Nice steady progress
What ceiling height are to targeting and what roof pitch (Degrees) are you going for
Regards
Pipoz
Postby Alan » Fri Jul 21, 2017 7:40 am
The ceiling height is 3.75m at the highest point. I want to go with a vaulted ceiling, not truly a vault but drops down around the edges maybe 30cm. Something I need to discuss with the contractor when I get there next month. The roof angle is 30 degrees so it will be quite high.
Alan
Postby Sometimewoodworker » Fri Jul 21, 2017 8:35 am
Alan wrote:The ceiling height is 3.75m at the highest point. I want to go with a vaulted ceiling, not truly a vault but drops down around the edges maybe 30cm. Something I need to discuss with the contractor when I get there next month. The roof angle is 30 degrees so it will be quite high.
Our finished height it about 3.6m in the lower section.
Something like this?
Postby Alan » Sun Jul 23, 2017 12:03 am
Something like that but closed in where it drops down.
Alan
Alan
Postby pipoz » Sun Jul 23, 2017 2:32 pm
How did your thread evade the Spammer :lol:
Postby Alan » Thu Jul 27, 2017 9:33 am
PIPOZ, not sure what you mean????
Alan
Alan
Postby pipoz » Thu Jul 27, 2017 10:31 am
Alan wrote:PIPOZ, not sure what you mean????
There was an Advertising Spammer who managed to to access the CTH Forum and drop his advertising crap into most of our Build Forums.
Looked like it was possibly Chinese in origin, but he missed a few of the Builds.
Anyway his message text/pictures have since been removed by the Moderators, so no big deal
Postby Andyfteeze » Thu Jul 27, 2017 4:56 pm
the only problem with the spam is that ironically, the spammer kills his own message. Obviously have psycological and sexual repression issues, lol.
Did that dick really think anyone was going to read what he posted? Idiots, you just cant shoot enough of them :lol: :lol: :lol: :lol: :lol: :lol:
Postby Alan » Sat Jul 29, 2017 8:02 am
They are working on installing the metal plates at the top of the wall columns.
Level and tac weld the plate to the rebar
Weld the rebar to the plate
grind off the excess
Paint the plate with primer
Add some primer to the underside
Alan
Alan
