saltwater chlorinator
Postby stevenff » Tue Jul 18, 2017 11:35 am
Hello,
I am thinking of bringing a Hayward salt water chlorinator from the US to Thailand but I am concerned about the electrical wiring difference. Would it be a problem? Thanks for any response.
stevenff
Re: saltwater chlorinator
Postby schuimpge » Tue Jul 18, 2017 1:00 pm
Not experienced with pool equipment, but in general, if the chlorinator is wired for 220v, then there's usually problem with wiring.
Be aware that this is Thailand and you should be sure about the wiring having been put in place properly at the place where you want to install the chlorinator.
Very good link with lots of info: http://www.thailandguru.com/electricity ... iland.html
Postby sjeng » Tue Jul 18, 2017 1:53 pm
I bought a hayward pump and filter some years ago they are wired for 220 V or 110 V just have to check before connecting to the grid. its just a small connector which has to be turned around and connected again. READ THE MANUAL and the sticker on the device it will tell you if its installed for 110 V or 220 V.
I think all Hayward poolstuf is constructed in the same way. GOOGLE for the chlorinator you want might help also.
sjeng
Postby stevenff » Thu Jul 20, 2017 12:18 am
Thanks guys!
stevenff
Postby Rdteth » Wed Jul 26, 2017 11:17 am
220 V should now be 230V. Years ago already. Although in thailand I never see that.
USA used to be 110V. Therefore you could not use stuff from there without some extra convertor.
Nowadays electronic devices have powersupplies going from 90 to 240V, at least from "reliable" companies.
So be sure to check the stickers on your device. If they say 110V you CANNOT use them straightaway here in thai.
Rdteth
Postby jazzman » Mon Sep 11, 2017 8:55 am
Never buy branded swimming pool equipment in your own country if it has an accredited distribution network in Thailand. Dealers and official service centres will not provide service under guarantee, and some will not provide service later either.
A note about Hayward: It is becoming increasingly difficult to obtain guarantee and/or service for this brand in Thailand. As far as I know, there is not one single official distributor. A friend of mine in Krabi bought 3 Hayward Tristar pumps (one for each of his rental houses with pools) from a Thai distributor, which were all professionally installed with all the correct components in the control boxes and within 6 months they had all blown up due to clearly faulty manufacture and Hayward refused to even acknowledge the problem.
Postby jazzman » Wed Jan 10, 2018 8:10 am
Technology changes and improves over time and prices of good quality equipment have actually gone down significantly since I started this swimming pool forum on CTH many years ago.
Automated chlorination systems, ionisers, UV, and ozone and systems often represent an important investment for many pool owners, although prices are now far more reasonable. When considering salt water chlorination, examine the market here in Thailand very carfully, there are currently only two brands that have a genuine customer and product support here, and that suppport is not offered by every retailer of those brands. A good salt water chlorinator should last for many years but the electrodes need replacing and you need to be sure thay will be available and not as in the case of the Poorite brand which went into liquidation leaving even no guarantee support for the Enduro and Surechlor models.
If you are having a pool built, be sure to ask your pool constructor what brand and model he intends to install (it may be old stock, and in some pool shops too). Also, very often the manufacturers' descriptions are often only advertised on performance in cool or temperate climates whereas pools in the tropics require a higher GpH output, and many pools builders may not be aware of this.
UV systems for pools have been introduced very recently at extremely interesting prices and which are now a viable alternative to chlorine and salt water chlorinators or ionisers, some of them are also equipped with additional ozone production at very little extra cost. After 10 years I have now replaced my saltwater system with one of these. The huge advantage is that it is less expensive to buy and requires no maintenance - no expensive electrodes or annodes to replace every few years (except the lamp which is not expensive), no need to stock salt.
