GFCI Receptacle
GFCI Receptacle
Postby maderaroja » Thu Feb 26, 2015 3:13 pm
Does anyone know where one may purchase GFCI receptacles in Thailand?
maderaroja
Re: GFCI Receptacle
Postby Sometimewoodworker » Thu Feb 26, 2015 3:47 pm
maderaroja wrote:Does anyone know where one may purchase GFCI receptacles in Thailand?
Every electrical shop together with all the usual suppliers DoHome, Global House, HomePro, ThaiWatsudu etc.
Most Safe-T-Cut distribution panels have one already fitted.
Re: GFCI Receptacle
Postby pattayapope » Fri Feb 27, 2015 1:06 pm
I have never seen a GFCI receptical in Thailand, you may be better installing a GFI breaker in the distribution board or alternately make one up with a small plastic enclosure with a GFI breaker and socket combination, any specific reason you wanted one?
PP
Re: GFCI Receptacle
Postby Shastadad » Fri Feb 27, 2015 1:29 pm
Expanding the OP's question
If I have a device that has a built in "safety panel" is it still necessary to have a separate GFCI Receptacle to plug it into ?
If yes, then where do you find a GFCI Recepacle that accepts a "european" style plug
eur plug.png (23.77 KiB) Viewed 296 times
Shastadad
Re: GFCI Receptacle
Postby Sometimewoodworker » Fri Feb 27, 2015 1:52 pm
Whoops. My bad. I overlooked the word receptacles
http://www.safe-t-cut.com/en/ Has them
Last edited by Sometimewoodworker on Fri Feb 27, 2015 2:19 pm, edited 1 time in total.
Re: GFCI Receptacle
Postby Sometimewoodworker » Fri Feb 27, 2015 2:17 pm
Shastadad wrote:Expanding the OP's question
No. But, some things should not have a GFCI like the refridgerator/freezer
